[TW]Fox;13019062 said:I just want MP
If I load the game with Social Club signed in it crashes with the MM10 error. If I logout of social club it loads fine but wont let me play MP.
Is the MP worth even keeping this installed for?
I think you guys who are looking to take it back should wait for a bit. It hasn't been out long, give R* a chance to redeem themselves.
They advise anyone that is encountering difficulties to contact their local technical support helpline for advice and recommendations. These telephone numbers can be found in the game’s manual. You can also refer to Rockstar's support site
Subject
Low perfomance
Customer (Entered by Thorvald) 03/12/2008 02.50 PM
Complain about getting only 15 FPS to 20 FPS
Response (Thorvald) 03/12/2008 02.50 PM
Hello,
Unfortunately getting 15 to 20 FPS with you computer configuration is normal. The game requires very high specifications in order to run above 20 FPS
Getting a refund from the
is nigh on impossible for PC games. They generally only take them back if they are still sealed and will try to blame all "unfit for purpose" and "it is a hideously mutilated mess of a game" logic on the specification of your PC.
That's shocking. They've released an unfinished product and are now refusing to acknowledge the problems people are having.snip
Thats all well and good but they say:
Well I done this and I called them about the low FPS I get on my setup (GTX260/E6400) which was told it is strange but they will raise the call up.
I then get the mail below from them:
How can they find out whats wrong if they think NOTHING is wrong![]()
in that case they should have listed a GTX260 as minimum requirements.![]()
Granted I can only run it on medium detail / high rendering, but the framerate is certainly better than the gameplay.
No it isn't. The new retarded panning of the camera (where it takes half an hour to follow the car around a corner) means that for the first half of any street, you can't see where the **** you are going.The gameplay is identical to previous GTAs from what I've played of it on the Xbox360
