- 29 Nov 2008
You can easily lift those metal jobbies, the cable will likely fit around the edge of the floor between wall and carpet gripper.... The metal thing will just hammer back down.
Buy some flat Cat5e.![]()
If your carpet has been fitted with proper carpet grips (ie hessian backed rather than rubber backed) you won't be able to refit your carpet properly (it requires a 'carpet kicker' and some knowhow).
