Lightroom2 vs Photoshop
28 Sep 2003
London
after having a play around with lightroom 2 (which i love)
i was just wondering which bits of your post porcessing you would do in lightroom and which in photoshop ? ie sharpening, contrast, levels etc ?
workflow wise, do you do the lightroom work first, then export to photoshop or the other way around ?...
lightroom first. its mainly a program for catagorising your RAW image files. You can do pretty much anything now in lightroom to make the image as fine tuned as you want. Photoshop is the tool with powerful clone/heal,dodge and burning tools. Photoshop allow you to break down the image and make layers and feather away at elements in your photographs and of course gives maximum control over color.
I use both programs as each image file of mine goes into photoshop for watermarking and saving low res versions.
Lightroom does pretty much everything I need.
Only time I've needed to chuck stuff into PS was when I had sand on my lens at the beach and didn't notice, but I could have cleaned that up in Lightroom too.. it's just faster in PS.
I'll also chuck stuff into PS if, for example, I need to make an exposure mask by hand.
I'd disagree that PS is faster for that. I've had times when I've shot for a whole day with a dust bunny in the frame; with Lightroom you can copy and paste a clone adjustment across all the images. Sure you need to check that in doing so you don't clone part of the subject but I find it easier to check and repair the minority than have to do a separate clone operation on every file.
I've tried to use lightroom to amend some pictures but it's learning a whole knew program.
I can do the exact same stuff in Photoshop a lot faster than I can in Lightroom. So I stick with Photoshop.
Thankfully, i'm such a brilliant photographer that most of my pictures come straight from the camera, a quick resize, auto level and watermark (macro'd) in PS and i'm all done. ;)
I use (and am used to) LR - dont like PS (as I dont like altering as-shot images - its either right or its not IMHO) will be upgrading to LR2 next week - works for me.
khushy
Good plug in but photoshop is never going to be put on the side. Its powerful in so many ways. It just isn't always needed to adjust photographs. I always sharpen my images in photoshop though.
Of course; I wasn't suggesting that Lightroom is a substitute for Photoshop, but with plug-ins it can take up some slack from Photoshop :)
Do you just use the sharpen and sharpen more etc from the filters menu? or is there a more complex tool i haven't found yet?
