- 14 Dec 2008
HIya mate (and others looking hehehe), saw a previous post you made with regards at a SPEC made for around £700.00
Now.... I have a 6-8 week old OCZ GAMER PSU 750w is this ok to use with the above stuff?
I wanted to "POSSIBLY" overclock at some point, not too much lol, so will that ram be ok or should I get something a little robust?
My case was the next question, a Lian Li which is 4 yrs old
http://www.overclockers.co.uk/showp...US Aluminium Midi-Tower Case - Silver (No PSU)
Thats as close as I can get to it, mine actually has 6 drive bays at the top not four, but as far as I can see, its the same apart from that.
I have a Dell 24" S2409W so dont need a monitor.
I have about £750.00 to spend, so I wanted to ask if you could recommend a larger capacity HD (Is there a decent 1TB one, and what is the difference between all the different colours of the Western Digitals?)
I have an old Creative Labs Sound Card (Audigy 2 Platinum) are sound cards obsolete now lol is the onboard sound as good?
Is there a fairly decent Soundcard if not you could spec?
Finally, and not often covered lol, Operating System? Vista 32 or 64bit? or summit else lol
Let me know anyone whos reading, want to try and do this pre Xmas
Chris
Hi and welcome.
I'm not sure what games will look like on a 46" TV but the PC I spec'd below will definitely play games on it very well at that res.
Chris
