Thanks for the info Photoshop.
I was wondering if you posted somewhere your entire hardware setup? Including the PC?
check my signiture
here is my headphone setup. I built the amp.
Sweet, should be an excellent player![]()
..I'm very happy with the performance of the amp. My only niggle is that at a particularly low volume, the left/right volume balance suddenly becomes uneven (issue with the quality of the volume knob assembly..?)Nice setup, wush! I'm aiming for something similar I think. Probably going to get the DACMagic, C355BEE and B&W 685. Already have a pair of DT770 Pros too!
How does your amp handle the speakers? Also, why not make use of the USB connection between your laptop and DAC?
O james very nice you sorted your cabinet situation out. Have you just plonked one LACK ontop of the other ? May I suggest you take them apart and build a proper 'dual lack' it would look better with the one middle part, although I'm not sure about the weight of each of your bits.
The laptop chucks out optical SPDIF natively so I (unfounded) guess at that being more robust than whatever driver the USB interface would use.
The 770 Pros are great. I like the sound and fit best in comparison to the highish-end phones I've owned before (HD650s, HD595s and narrowly the K701s)![]()
I've got the 685s around a foot from the wall and the bass is good, nice and tight....there isn't a ton of it but then again they're not massive speakers (smaller than the previous series) and what they output is nice and high quality. Plus I just whack my sub on when I want some fun![]()
Should only just boost the bass - as they're front-ported it shouldn't cause any adverse side effects except perhaps too much bass, but then imo the tweeter on the 685s can far outpower the midrange/bass at higher volumes anyway.Whatever speakers I get, for the time being, will have to sit around an inch or two from the wall on my desk which isn't exactly ideal! How is this likely to affect the sound (bearing in mind these are front ported)?
Oh and sorry for chatting so much in the picture thread!
, I'm well chuffed, thanks for the rec. Need a new camera though and tv stand. Had to stack it on top of the amp with 2 dvd cases to allow airflow. Hopefully the amp wont over heat. Shall find out just got the Iron man so will be watching it.
updated mine and moved it around recently
excuse the mess of mains cables underneath - you can't see them at normal angles- should sort it though ! lol
