Hi, I'm building a gaming PC as some of you may know, and I've bought the following parts so far
GPU: ATI Sapphire 4870X2 2GB
CPU: Intel Q9450
The following are my proposed specs. Please could someone help me URGENTLY by telling me 1). Whether these parts will actually work together 2). Whether I need any extra cables etc and 3). Any cheaper alternatives.
Here are the rest of the Specs:
MOBO: ASUS P5Q PRO
http://www.overclockers.co.uk/showp...P45 (Socket 775) PCI-Express DDR2 Motherboard
RAM: OCZ 4GB (2x2GB) PC2-8000 1000MHZ DDR2 Ram
CPU Cooler: Arctic Cooling Freezer 7 Pro (LGA775 Version)
Case: OC-UK Antec 900 Modded Version
http://www.overclockers.co.uk/showp...x" Antec Nine Hundred Case - Red Fans (No PSU)
OR Thermaltake Armor+ MX VH8000 SWA
http://www.overclockers.co.uk/showp...Super Tower Case with Window - Silver (No PSU)
HDD: Samsung SpinPoint F1 500GB SATA-II 16MB Cache - OEM (HD502IJ)
http://www.overclockers.co.uk/showp...nt F1 500GB SATA-II 16MB Cache - OEM (HD502IJ)
Optical drive: LG....
http://www.overclockers.co.uk/showp...20Dual%20Layer%20ReWriter%20(Black)%20-%20OEM
So what I really need to know is, will a 4870X2 fit in those cases, will the CPU cooler fit, do I need any extra cables to connect the parts together, are these parts even compatible together, and are there any cheap alternatives. I think that Gigabyte do P45 motherboards which are similar and maybe cheaper than the P5Q Pro, if so can someone please recommend one to me.
Thanks and please reply soon, as I want to buy the products TONIGHT
EDIT: I've just realised that I forgot to show a PSU, could someone please recommend one for me, that will be able to handle the GPU and CPU, taking in mind that I will O/C the CPU ?
CPU: Intel Q9450
MOBO: ASUS P5Q PRO
Are their any cheaper coolers you would recommend
But I'd still like to hear your thoughts on that PSU
