hi all.
just changed my mobo(asus A8R MVP crossfire socket 939) cpu(3800 x2) and ram(2 gig ocz ddr) to a gigabyte ga-ma770-ds3 mobo, amd 6000x2 and 4 gig of patriot ram.
big deal you might say but! my copy of vista 32bit is an OEM copy.
everything went according to plan untill i started it up and tried to enter the bios so i could load from my vista disk after formatting my hd.
basically it didn't let me, it skipped the bios and loaded straight from the hd, then when vista loaded it then procceded to install all the usbs etc for the new mobo.
then about half an hour later when i made sure everything was ok(and it is
the "new hardware detected, vista must be activated within 3 days" message appeared, i then thought **** here we go. so i clicked activate and hey presto within 5 seconds it was activated
now i thought you weren't supposed to be able change hardware just like that and for it to still work. also activate vista so easily
