Overclocking help
That seems to be it. Running prime now ok, tried at 3200mhz but it did the bsod trick once at the desktop, dont really want to put anymore vcore in than it has currently or i'm gonna be heating my room :p
That looks better, I'm just wondering how fast your memory is running in the above screenshot?
I'd say thats a good place to get some stability testing done but I'm sure you can get more without too much effort, If the memory isn't set to 1:1 then now may be a good time, the only thing that will hold you back is vCore, vNB and perhaps the chip actually topping out!
If you have a good chip and the mobo can handle 400MHz then you may be hitting anything up to 3.6GHz
Well its made a massive difference to mmo framerates, most happy thanks ;)
Good stuff enjoy! :)
up to 3240 now at 1.45vcore, things starting to get quite warm though! 63c @ 100%
The mobo has a passive cooled NB thats now getting almost too hot to touch also :(
