Can you stream BBC Radio on iPhone?
27 Aug 2004
Singapore ExPat
Very tempted to get one when my contract's up next month but sadly I do like to listen to the news on my way to work. Can you stream Radio 4 on the iPhone or is there another way? Cheers
Buy Wunder Radio from the app store, costs a couple of quid but you can stream pretty much any station you want (including international).
Does anyone else get this error when trying to download from the app store?
I have a 8gb 3g iPhone running 2.1 firmware.
Downloaded on jailbroken 2.2 and works fine. I downloaded it via iTunes then synced my iPhone. Just tried Radio 1 and 5 Live, works perfectly! I was going to pay couple of quid for an app in the store but this works just as well :)
WunderRadio is brilliant, has so many stations from all over the world, it even views the nearest stations according to your location through gps
(iTouch) Well - the links (BBCstreams) do not work on the iTouch and Fstream wont install on an iTouch with the updated software - so does anyone konw a way to stream BBC R4 or BBC R7 to an itouch. I know the iplayer works but I can't seem to stream live BBC radio - some other streamers on the "App Store" say "can't do BBC at the moment".
Anybody cracked this please? :(
I use Fstream on my Iphone 2g 2.2version software and I stream the links over my wifi without any problems. I have streamed Radio2 , 5live and Radio 4 without any problems at all. I am running unlocked software but no jailbreak though. Do you get an error message when running Fstream?
Rob H
I get the message as above - "not compatible etc" when I try to install FStream on my iTouch; i.e. it won't install.
