at which point a flag will be raised in the ECU memory and your dealer should notice this and advise at next service?
I've thought of some more:Probably best not to try that unless you want to kill it
That's a good idea - if you put the climate control at 32 and leave it on for ages will it warm up enough to be able to use it like a large oven?
I bet you've already tested that![]()
2. What effect does using 1 spacesaver tyre on the left, rear wheel have on the 0-60 and 0-100 MPH times?
I don't know why people think that running low on fuel will 'suck in all the crap from the bottom of the tank'. The fuel is constantly pulled from the bottom of the tank anyway?
I'm going to have to try this out, and I even know where I'm going to do itHow about a spacesaver on the rear on one side and on the front on the other, what does that do for handling?
I might try greasing them up first, too, effectively giving the car 2 wheels with any usable grip.I expect it'll do lots for the handling - cause a big accident![]()
( |-| |2 ][ $;13212522 said:Exactly. It's an myth.
How high can the HVAC system raise the interior temperature?
Agreed. We need to agree on a standard cheap termometer from Tesco or something, and the rule is you must stay in the car for all 10 minutes. The car must be at normal operating temperature at the start.I reckon we should all try this, and have a competition, climate control or not. Highest and lowest interior temp after, say, 10 minutes?![]()
Also you must be using the car's standard HVAC. If anyone cheats by using external systems, I will counter-cheat by setting my car on fire.
Like what? Examples? Proof?It's a well known fact that any crap that is in your fuel tank floats in petrol.
Truth.
