Windows 7 Beta 1 (build 7000) screenshots
New 181.20 WHQL nvidia drivers are out.
It must be compatible with windows 7 ?
/waiting until tomorrow for the public beta :mad:
I find the feature in this google vid the best, used to hate on vista having loads of windows open at the bottom and then trying to find the one you wanted, i know that had the feature you could scroll through them but i always found that more trouble than it was worth.
that looks much tidier than vista
the quickpreview in vista is handy, but as you said, it's pretty cluttered
Well I've done it. Win 7 x64 as my main OS! Lets see how it goes, everything is working fine so far. Will try to get a beta key tomorrow, then hope I can activate it (didnt enter a key when I installed it)
I'm having problems with motherboard drivers for the Asus P5E-VM HDMI, the installer won't recognise the operating system and i can't update drivers from device manager either.
Installed x64 on a laptop at work (HP 6930p) and the install process was very slick. At the end windows failed to find only 2 device drivers, a lot less than Vista. This new task bar is taking some getting used to but I'm giving it my best shot!
I have installed Windows 7 Beta 1 (7000 Build) everything has went lovely and smooth. EXCEPT Catalyst Control Centre, i cannot get the buggar to install, i have tried countless times, used driver cleaner then tried again and no look, it stops when i get to detecting the video card in the installation process and does no further work from then on.
Does anyone know of a fix?
Forgot to mension above i am using a 4870
