- 7 Feb 2004
Lucky boy
You mean you actually checked thenm side by side ?
What can I say I was so excited when I got my new card and it was early in the morning...
Lucky boy
I got 14,400 with comparable rig to yours so I'd say you're doing well
yeah i s'pose, will have to make up my mind by tomorow, will have to sit on it for 2-3 weeks if i get though till i get my new comp.
Also will this fit in the antec 900 case?
I increased my overclock on the Q6600 to 3.4Ghz and re-ran 3DMark06, now getting 16,321![]()
I know it's not a 280 but as a comparison i got 15625 with my 4870 512mb and system in sig.
4870 512mb Score
how does your 4870 compare Matty Boy
Mine is 10.5inches long. And I think the card is about the same!
anyone know where you can get hold of a cheap vantage activation code? I cant find it on ocuk... please point me in that direction if its there..
Are you sure you are using the correct slot?I wish i had 10.5" instead of this great big thing i have, i can hardly fit mine in the slot![]()
If it's just the serial no. you need then you can have mine, I never benchmark anyway. I'll try and get hold of it this evening when I'm home.
Mods: if this isn't allowed or if it's illegal then let me know.
Sorry if this has been asked etc. But when are the 285 due? How much will they be? Is it just worth picking up a cheap 280 if you have 250 max to spend.
Thanks.
Unfortunately I cannot confirm anything you have asked.
The mega cheap GTX 280s have now all gone.
Theres 1x ASUS GTX 280 in the B-Grade for £241 if anyone fancies taking a chance on it.![]()
