- 21 Jan 2003
- Northamptonshire
NOW RESOLVED.
if you have your bios pci-e clock set to 110mhz which was fine with an ati 4870x2 it seems the 295gtx doesnt like it. I have set it to 101mhz now and all is just fine.
Hi Guys,
ok gonna have to hold my hand up, i was sucker for the 295gtx,
Anyways a clean install. using 181.20 drivers. every time i launch vantage it gets to the same point and hard locks.
Same in games, i can play for about 45secs then the display hard locks, im unable to alt tab or anything, Strange thing is i was on skype chatting to a mate and that was fine still.
Any ideas
Im new to the nvidia camp
psu is fine Bequiet 1200wat
asus p6t oc palm
Core i7 920 @4ghz temps on that are fine its under water.
My ATI 4870x2 is fine when re-fitted again with a clean install to be sure an it works fine
doesnt look good for the 295gtx
is it possible i received a faulty card?
Hi Guys,
Any ideas
asus p6t oc palm
