Whats this check for change thing
https://www.microsoft.com/betaexperience/productkeys/win7-64/enus/default.aspx
Does the 64 bit key work with the 32 bit version?
I finally got a key!
Just try and get a 64-bit key, as apparently they work with 32-bit versions of the beta aswell.
I am using this link:
Code:https://www.microsoft.com/betaexperience/productkeys/win7-64/enus/default.aspx
Is that right?
Is that right?
anyone got the link for the 64bit key page then? would be much appreciated
ive had check4change goin for 30mins now and nothing, is there anything i need to sign up for?
I used this link to get my key, with success:
https://www.microsoft.com/betaexperience/scripts/gcs.aspx?Product=tn-win7-64-ww&LCID=1033
