Enabling AHCI after windows install?
7 Jun 2003
Gloucestershire
I've read that there are ways to do this but only ways that seem to work in XP, i've tried the same ones under vista but it didn't work
Can anyone tell me if there is a way to enable AHCI after installing windows 64bit?
I don't recall any issues in Vista32 other than just changing the setting in the BIOS (ASUS P6T). I enabled it after installing the OS trying to get eSATA working. Maybe your problem is motherboard-specific?
1. Exit all Windows-based programs.
2. Click Start, type regedit in the Start Search box, and then press ENTER.
3. If you receive the User Account Control dialog box, click Continue.
4. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Msahci
5. In the right pane, right-click Start in the Name column, and then click Modify.
6. In the Value data box, type 0, and then click OK.
7. On the File menu, click Exit to close Registry Editor.
This worked for me, hope it helps :)
Vista does have native support for AHCI. If you just enable it you may end up on the Windows drivers. Getting the Intel drivers to work is possible.
See also > http://support.microsoft.com/kb/922976
Cheers guys that seemed to do the job :)
This defo works in vista home 32 bit. Tried it the other day. Kinda pointless as I had to re-install a few days later to set up my raid array. Oh well :)
