If I installed win 7 again will my key still work? Cos Ive messed win7 up a bit
yes
What did you install it as, Vista?It's running nicely in VMWare Workstation for me![]()
Can anyone get 4oD to work?
Close MSN/WLM completely, then right click the shortcut to it. Go to compatibility and select to run it in Vista compatible mode. It'll minimise to the systray instead of the toolbar, then![]()
Has anyone had any luck removing the "for testing purposes only" watermark? Tried several ways to do it but none are working!
I think I hit 'next' by mistake before entering a key but it seems to of finished the installation, does that matter?
