The All New Desktop Thread, Images No Larger Than 800x600
I need a new Graphocs card and Monitor to get the full efect of Win7.. :(
Anyhew.. a little Fettling (1024x768)..
Gotta install a decent Image Program.. Windows Paint isn't bad!!.. but I need CS3 or summut!!
InvaderGIR what you using to swap the backgrounds?
It's built into Windows 7. :)
But...on XP I use Adolix Wallpaper Changer on one machine, but it's not as good as the one I use at work...which brilliantly I have forgotten what it's called and don't have it on a USB drive or anything.
EDIT: To do it on W7.
Right Click Desktop > Personalize > Desktop Background > Then tick all the images in the folder you want to rotate trough. :)
Cool cheers for that, if you remember what the other one is let us know. :)
