- 19 Feb 2007
- Northampton
until the beta is over
My Audigy 2 ZS worked with the default drivers, or maybe there was an update I did later that gave me drivers.So are there any creative drivers that work with windows 7?
Loaded AVG 8 and it works fine on 32-bit installation and it works OK(?) It loaded, then updated itself with no errors. I haven't run a scan yet though.....Same here, on 32-bit...
FrapsChannel (3 hours ago)
I think I'll be staying with Vista till Windows 8 lol.
I have the Windows 7 Official Desktop Backgrounds anyways.
buckamoona (5 hours ago)
its been made for retards..normal people will be ****** at how simple yet annoying it is
I put in an old 40gb harddrive and installed Win7 on it. It all seemed to work okay, took about half an hour to install. However after entering the OS choice menu on startup and selecting Windows 7 it says that it cannot find hal.dll.
This could have just been an error on installing but I think it's more likely that not installing it on the boot drive caused a problem. I had a look through the startup options with VistaBoot Pro and everything looks fine, it's pointing at the right drive for everything. I've confirmed that hal.dll is where it is looking it just can't find or load it.
I might try removing my main system drive, reformatting the 40gb drive and try to install Win7 on that then. Hopefully if that works I can put the current system drive back in and sort out the OS choice menu after that.
That possibly only works if the Vista install is 64bit as I tried to install Windows 7 64bit from within XP 32bit but it refuses to install forcing the use of a DVDI suggest reinstalling, which can be done within Vista itself by mounting your image and running the install from there and selecting you target drive for install.
The problem is not the seperate drive as my install is done this way. Boots from my Primary Vista disk, but the W7 install is on a seperate hard drive. I suggest reinstalling, which can be done within Vista itself by mounting your image and running the install from there and selecting you target drive for install.
The program can't start because OpenAL32.dll is missing from your computer. Try reinstalling the program to fix this problem.
