Save the £200 for something elseMaybe some nice 5.1s
True, Erm buy something else then. A hooker for the night or something
couldn't wait anymore and the pioneer got snapped up, she'll be here tomorrow![]()
it arrived yesterday but i was a bit busy, now i have a little problem.
the speakers i was going to use as the surround backs to make up the 7.1 are kef 60s, they are rated at 4ohms. the amp only does 6-12ohms. should i just leave them off till i get new speakers or will they be ok? the other speakers are rated at 6ohms.
my last amp was a sony str-db 940
james where did you see that its only rated for 130w with 10% distortion?
in the manual i can only see this relating to 130w
Rated Power Output . . . . . . . . . . . . . . . . . . . . 130 W + 130 W (20 Hz to 20 kHz, 0.09 %, 6 Ω)
also i think your right about the 58w per channel, i had a sherwood amp that was rated at 65w per channel and tbh it sounds about as loud as that so far and no where near as loud as my sony which was rated at 100w per channel iirc.
how can they get away with saying its 150w p/c when it clearly isn't?
the problem is, not only is that only a 2 channel output spec (it would say all channels driven if it wasnt, but that is standard practice) but they also dont state RMS anywhere (again, unfortunately is pretty standard practice with av amps) so in reality they can get away with stating anything.Amplifier section
Maximum Output Power (1 kHz, THD 10.0 %, 6 Ω)
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .. 180 W/channel
Continuous Power Output (DIN 1 kHz, THD 1 %, 8 Ω)
Front . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 130 W + 130 W
Center . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 130 W
Surround . . . . . . . . . . . . . . . . . . . .. . . . . . . . 130 W + 130 W
Surround back . . . . . . . . . . . . . . . . ..... . . . . . 130 W + 130 W
Continuous Power Output (DIN 1 kHz, THD 1 %, 6 Ω)
Front . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150 W + 150 W
Center . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150 W
Surround . . . . . . . . . . . . . .. . . . . . . . . . . . . . 150 W + 150 W
Surround back . . . . . . . . .. . .... . . . . . . . . . . . 150 W + 150 W
Rated Power Output (20 Hz to 20 kHz, 0.09 %, 8 Ω)
. . . . . . . . . . . . . . . . . ... . . . . . . . . . . . . . . . 100 W+100 W
Rated Power Output (20 Hz to 20 kHz, 0.09 %, 6 Ω)
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 120 W+120 W
its a whole different league, confirmed by its 740w maximum draw. notice also that they state the rated outputs are @ 0.08% distortion and the power in to 2 channel is much higher. ITs far more capable of driving a set of speakers and being THX ultra certified is rated for output down to 3.2ohmRated Output Power
All channels:
...........North American:
130 watts minimum continuous power per channel, 8 ohm loads, 2 channels driven from 20 Hz to 20 kHz, with a maximum total harmonic distortion of 0.08% (FTC)
145 watts minimum continuous power per channel, 8 ohm loads, 2 channels driven at 1 kHz, with a maximum total harmonic distortion of 0.7% (FTC)
160 watts minimum continuous power per channel, 6 ohm loads, 2 channels driven at 1 kHz, with a maximum total harmonic distortion of 0.1% (FTC)
...........European:
7 ch × 180 W at 6 ohms, 1 kHz, 1 ch driven (IEC)
Others:
7 ch ×180 W at 6 ohms, 1 kHz, 1 ch driven (IEC)
7 ch × 230 W at 6 ohms, 1 kHz, 1 ch driven (JEITA)
Dynamic Power 300 W (3 Ω, Front)
250 W (4 Ω, Front)
150 W (8 Ω, Front)
THD (Total Harmonic Distortion)
0.08% (Power Rated)
Damping Factor 60 (Front, 1 kHz, 8 Ω)
