- 22 Aug 2005
- Clydebank
You want to spend £200 on a mac for day to day use AND hook your DSLR upto it? You're throwing £200 away. It'l be old, underspecced and generally a hog. Why bother?
But it'll be cheap... and a step into Macintosh land. If I like it I could in a year or so when 10.7 comes out, possibly upgrade [the hardware], (10.7 is likely to drop PPC support 100% from what I read), or if it works fine for my needs keep it as a great value machine... Why would hooking up a camera be a problem?
I'd save up a bit more and get a Mac mini tbh.
The best you'd do with £200 would probably be a late G4 iBook or iMac. These would be perfectly functional but it would be better to spend that little bit more and get an Intel Core based machine.
Are you suggesting new, or second hand ? Either way, I can't find any minis in a reasonable price range. A mini is appealing though. Someone mentioned they are doing new minis? When are they due? Perhaps could get a bargain on a old stock?
Why would I want in intel core based machine over a PPC machine? Given that 10.5 still supports PPC machines and by all reports runs very nicely indeed? !0.6 is supposed to be a minor upgrade and 10.7 out in 18month+ time is likely to drop PPC support (maybe) But that doesn't mean my machine would stop working.
As others have said, you might be able to get a late G4 dual MDD, should be snappy enough.
Indeed - snappy enough?, sounds good to me that's what I'm wanting... Would it run CS2 (very) nicely, given CS2 is a PPC binary and not intel native? So I have read.
thanks for input ...
