I've made a new shuttle and had two problems before (see my other threads) with installing the OS iI've now managed to install it via another comp and put the hard disk in and now itwill boot up to windows load screen not load and then go to a blue screen saying:
A problem has been detected and windows has been shut down to prevent damage to your computer.
Check your hard for viruses. Remove any new hard drives and controllers. Check hard drive to see if it's properly configured and terminated. Run CHKDSK /F to check hard drive corruption and then restart.
Technical Information:
Loads of code!!!
It wouldn't have any viruses it hasn't been able to get an. If I remove this hard drive there isn't any others and I don't know about controllers. I don't know how to see if it's properly configured . How would I run that in BIOS because I can't get into Windows.
Please help I'm so desperate and gutted one problem after another keeps happening and I really want this comp to work.
Loads of code!!!
