Feser Xchanger - Quad Radiator 480
What's its performance like compared to the Thermochill PA120.3?
I'm pretty sure it will fit in my case, Silverstone TJ07-WB. Has anyone got it in this case?
Hope someone can give me some info.
It will fit your case no problem,its the psu thats the problem as in your case it would stop a quad rad working as it would block up one fan,you can still go with the quad as ive seen them in the TJ07-WB.
Can you explain abit more please? Surely it will work the same as the triple rad. You have the 4 fans on it sucking hot air away from the rad and out of the case. The PSU will be next to it, or have I got this completely wrong?
RoEy
