How to find out your phone number?
1 Dec 2005
Stoke on Trent
We have a phone socket in our house and it had a dial tone. Is there a way to discover its phone number?
Obviously ive tried to ring my mobile from it but outgoing calls are barred. Is there a way of discovering its number?
Use your mobile.
start at 00000 0000000 and increment by 1 each time.
When it rings, you've found the number :D
[SKR]Phoenix;13321292 said:
plug a phone in and dial 17070. Listen to voice on other end.
also, press 2 for a quiet line test if you want.
EDIT: DOH! TOO LATE!
17070 is for quiet line tests isn't it? 174 used to tell you what number you're connected to. Try that :D
I find that if you dial the number 17070 you should be able to find out your phone number. Dont listen to these other noobs!!!!!
