- 26 Feb 2007
- Blackpool
SPAM MAN!
you should get out more![]()
I looked at your post count and thought that looks very close to the max for a signed integer (I work with SQL a fair bit). However it is over the max for a signed int so it is likely that its stored as a INT and the DB is MySQL as that supports unsigned INTs. I need to get out more.
I don't post enough anymore
will get to 10k soon enough though
Well then, deploy the Spiebot.
i seen one guy with like 72,000 posts!I dont know who it was but he must literally sleep at his pc table![]()
I will auction my post count if you like. £10 per ten thousand posts.![]()
That's got to be Fox...
[TW]Fox how many of your posts are spams?
