I looked at your post count and thought that looks very close to the max for a signed integer (I work with SQL a fair bit). However it is over the max for a signed int so it is likely that its stored as a INT and the DB is MySQL as that supports unsigned INTs. I need to get out more.
My real post count would be 20,000 more than this I think but I gave away 10,000 for a couple of post count auctions, couldn't afford to bid so thought that would be the next best thing.
A brief look at your post history suggests that you struggle to write more than two sentences per post, with little or no substance. At least Fox contributes a lot of positive stuff here.
