A little tutorial. (Fogive my english, i'm spanish, bad public education).
HOW TO: INSTALL CS3 (OSX) ON A MSI WIND, ADVENT 4221 OR MEDION AKOYA WITH INDESIGN AND ILLUSTRATOR
What you need:
- An image disk of CS3.
- Springy 1.4.1 It allows open rar files and edit dmg's quickly.
TEN SHORT STEPS
1- Create a New Folder on Desktop
2- Open CS3's DMG with DiskImageMounter and copy all the content on the new folder.
3- Go to ADOBE CS3 DESIGN PREMIUM folder.
4- GO TO: payloads>adobeindesign5es_ES (your english version must be en_EN instead of es_ES)
5- Open adobeindesign5es_ES.dmg with SPRINGY: Open for modification.
6- Drag Proxy.xml to the Desktop and open it with TextEdit.
7- You will find this at the end:
{"Width":"1024","Height":"768"},"Exclude":{"Width":"800","Height":"600"}}}
8- Change it for:
{"Width":"1024","Height":"600"},"Exclude":{"Width":"800","Height":"400"}}}
9- Save and drag it to SPRINGY into the same place you found it: Replace and Save. Quit Springy.
10- Do the same with Adobeilndesign5es_ES.proxy.xml, (or Adobeilndesign5en_EN.proxy.xml) it's on the same folder that the last dmg file.
You have changed InDesign requirement. Do the same with Illustrator.
And SETUP!!
