Installing CS3
16 Oct 2007
UK
I'm trying to install CS3 on my NC10, but it won't install due to the resolution (600 high instead of the wanted 768)
Any ideas how i can get this installed? It's only for the occaisional work so i realise the screen won't be great for lots of stuff...
This might help, stole it from another forum
A little tutorial. (Fogive my english, i'm spanish, bad public education).
HOW TO: INSTALL CS3 (OSX) ON A MSI WIND, ADVENT 4221 OR MEDION AKOYA WITH INDESIGN AND ILLUSTRATOR
What you need:
- An image disk of CS3.
- Springy 1.4.1 It allows open rar files and edit dmg's quickly.
TEN SHORT STEPS
1- Create a New Folder on Desktop
2- Open CS3's DMG with DiskImageMounter and copy all the content on the new folder.
3- Go to ADOBE CS3 DESIGN PREMIUM folder.
4- GO TO: payloads>adobeindesign5es_ES (your english version must be en_EN instead of es_ES)
5- Open adobeindesign5es_ES.dmg with SPRINGY: Open for modification.
6- Drag Proxy.xml to the Desktop and open it with TextEdit.
7- You will find this at the end:
{"Width":"1024","Height":"768"},"Exclude":{"Width":"800","Height":"600"}}}
8- Change it for:
{"Width":"1024","Height":"600"},"Exclude":{"Width":"800","Height":"400"}}}
9- Save and drag it to SPRINGY into the same place you found it: Replace and Save. Quit Springy.
10- Do the same with Adobeilndesign5es_ES.proxy.xml, (or Adobeilndesign5en_EN.proxy.xml) it's on the same folder that the last dmg file.
You have changed InDesign requirement. Do the same with Illustrator.
And SETUP!!
i know it says it is for osx, but maybe the files are similar?
EDIT: apparently CS4 doesn't check the minimum resolution, maybe upgrade to that.
thanks chief - i'll certainly give it ago - work has CS4 i could install, although not sure how the NC10 will handle it!
I'm using CS4 on the Samsung NC10 and the resolution is not a problem.
I do however have my palettes laid out in a way to not obstruct screen space though.
