-== Weekend Graphics Deals! ==-
Oh God. Been toying with the idea of getting an X2. Had decided that I wouldn't. Now I'm tempted again.
Will my IP35 Pro bottleneck this card?
Will my 600W Seasonic be enough? (only has 2 6 pin PCI-E cables)
Do I actually have any willpower??
Ok. So what way do the connections work?
2x6pin PCIe via adapter -> 8 pin port on card then
2xmolex via adapter -> 6 pin port on card ?
Are these included with the card?
Any chance of a deal on the GTX295, I'm hovering on the buy button but just a bit too much to make it comfortable right now ;)
Although I am looking at the 4870x2 now :o
Oooh what to do!!
Only you can answer the do i have any willpower Question :p
but i bet Yewen etc hope the answer is No :p:p:D:D
They will xfire well with a 4870 1gb ;)
Never thought of that - could use this and keep my current 1GB card. What sort of psu would be required for an x2 and 4870 1gb though? :eek:
...or is there physx equivalent from ATI that I could use the single card for?
OpenCL will work, but the third card will show a performance boost in some games.
Makes more sense than 2x 4870 X2, you can run it on a 650w Corsair TX but I would recommend a 750w depending on your system.
