Prog to convert documents to PDF + A good text to speech prog for Office?
4 Feb 2004
Écosse
Hi,
Looking for two programs of some sort capable of doing the following :-
First, I'm after a program that will convert different types of documents into .PDF files. Would like to be able to convert the likes of Word docs, Excel etc. If there's one out there that can convert Office 2007 Word .docx files, even better.
Secondly, a friend of mine has a visually impaired daughter who is starting to use their PC more and more but gets frustrated sometimes trying to read things.
His old PC had some sort of plugin/addon for Office 2003 that allowed her to listen to .doc files but his new current PC has Office 2007 installed and as far as I can tell, text to speech only works for Excel in that.
So is there a prog available that can convert documents from text to speech that is simple to use. Preferable one that is seamless in operation and doesnt require a document copied and pasted into it or opened up within it?
If anyone knows of some sort of plugin for Word 2007, that would be even easier for her to use. I see from Googling it that there is some sort of method using Macros but it looks a little complex for a kid to use.
Ta.
Personal reccomendation of course, but I use CutePDF (free) to convert any document to PDF. You print the document to CutePDF printer and it outputs a PDF file. We use this widespread at work and have no complaints.
http://www.cutepdf.com/
I don't really have a reccomendation for text to speech as it's something I rarely use. However on the odd ocassion I feel the need i've got a copy of Speaking Notepad.
Think this is the website;
http://www.qwertystudios.com/ ?
It came free with a magazine so their might be a trial.
Thanks guys.
So this CutePDF program, does it actually convert say a Word .doc to a PDF file which you can then actually save as a PDF file or does it send the Word doc to the printer and it prints out as a PDF file?.
Sorry if that sounds thick, just not sure if it does or not?.
Thanks guys.
When you select to print via cute pdf nothing prints out it just asks you where u want to save ur new pdf document.
Hope that helps.
