- 27 Jul 2005
- The Orion Spur
9%
Calm down dear - its only a demoI'm on 10MB Virgin and I appear to be getting 1.5MB actual download speeds. I have said it before, but I will stress it again... IF YOU WANT FAST DOWNLOAD SPEEDS FROM PSN THEN USED WIRED OVER WIRELESS. IT MAKES A MASSIVE DIFFERENCE!
If I play a game, will it continue downloading?
If it uses any online ability then the PS3 will stop your dling IME...
ps3ud0![]()
Make a KZ2 snowman and post it here...
ps3ud0![]()
How about watching a DVD?
Watching a DVD is fine, the download will still continue.
Watching a DVD disables downloads. As pseudo said, you need to play a game in single player (not GTAIV tho as that still disables downloads)
IF you want to be certain, just fire up a game, go into the XMB and see if the download is paused. If not, you're fine.
I've been playing a AVI from my server and it was still downloading and I'm sure I've had the same thing with DVDs. Could be wrong tho![]()
AVIs are fine as you can still access the XMB while playing em, DVDs completely disable the XMB and disconnect your PS3 from the net last i checked. When the PS3 first came out it did allow net access while playing a DVD but it caused stuttering issues when upscaling so they disabled it.
