How to make facial hair white
Maybe..... you'd be just as daft supporting Celtic though !!!
Enough threadjacking, get some work done ;)
White hair dye is definitely the way to go. Get some of the spray on stuff that's basically like spray paint. It'll wash out and you can do the rest of your hair as well \o/
Depends how much hair you have and how often you want to repair the white but dry shampoo (aerosol) works well for the head but you would have to re-apply it after a while. Non damaging to those around too.
You can get aerosol cans of spray on hair dye, have a look in your local joke/fancy dress shop, it'll look good enough for your purposes and should wash out after a couple of showers.
You can get that spray stuff from fancy dress shops. We got a load when i was 16 and pretended to like football, so that we could spray England flags on our heads (we were awesome. I'm not even English.). Gems up Moulsham Street in Chelmo does it. Are there even any fancy dress shops in Brentwood? Dont remember any.
