Just a query. I haven't applied any themes to vista but did so with xp a couple of years ago which just ended up causing instability.. I do like some of the themes available for vista but a little worried about installing them.. Anyone had any issues?
I tried installing some themes on Vista 64 a few weeks ago. I followed all the instructions, system restore point, etc, etc and still managed to mess it up!
Fair enough I made some mistakes myself - but make sure you know what you're doing![]()
Where did ya get them gadgets on the sidebar Shining.
).Can i have a link to the visual style you're using?
Thanks!
That brings back memories, used to own one of those many years ago
Shame it was a hunk of crap that was falling to pieces, was nice to look at though (from a distance).
Those are yahoo widgets. Just have to pick the right ones for a good look and function. They can be moved around too. I love'm.where did you get that clock from on the sidebar?
In your notification area there is the icon where you can set not to load those at startup and also exit them. Alternatively you can change your startups with "msconfig".also does anyone know how to remove
so to have a clean sidebar?
