I want to put a Mutant in my car..
Cheers,
James.
Maximum Output Power 50W x 4
Auxiliary input Yes, Front
Auxiliary Type Mini-jack Built-in
Pre-out 1 RCA
Pre-out Output Level 2V
Preout Rear / Subwoofer Switchable Yes
Subwoofer Reference Level Adj. Yes
Source Tone Control & Memory Bass / Mid / Treble
Balance/Fader/Loudness Control Yes
Att.(-20dB) with smooth Volume Return Yes
System Q (Preset Sound Control) Yes
Bass Boost Circuit Yes
Low-pass Filter Yes
sorry...im being immature today, i'll get out cos I dont know anything about this....
I didn't think they did anything less than 2/3 pre-outs these days, even my old headunits had 3 a piece.
I bought a Blaupunkt DAB54 from a friend who bought it new for about £350. To my surprise, it didn't come with the pre-out lead. I had to buy that seperately!
It was only £6 so i'm not that fussed. That's got 2 front and 2 rear outputs aswell as the remote connection![]()
So in order to have a sub i have to get rid of my rear speakers :|
The Mutant MTSPB12 has a class D amp! O.o
Let us know how it sounds...
The block connectors on the headunit run the standard speakers, the pre-out phono output on yours is to run to an external amplifier which can power whatever speakers you want, IE the sub.
The headunit sounds like it has an option in the menus to switch the pre-out between stereo full range signal or a mono bass signal so you'll be fine to use a sub with it.
Mutant are essentially the cheaper version of Vibe IIRC. The kit isn't meant to be too bad.
I normally scoff when I hear brands such as Mutant or Vibe, but class D makes perfect sense for a sub. It's nice to see a little ingenuity despite the fact it's bargain basement product.Mutant are essentially the cheaper version of Vibe IIRC. The kit isn't meant to be too bad.
I normally scoff when I hear brands such as Mutant or Vibe, but class D makes perfect sense for a sub. It's nice to see a little ingenuity despite the fact it's bargain basement product.![]()
Brilliant, will a basstube run from the HU without an amp?
300 Watt MOSFET Amplifier
Thanks.
