how do you stop rattling when you put a sub in the car? like rattling of door pannels or whatever?
have you installed an alarm?
you have a very cheap car that will be easy to break into, might be worth considering that before you spend out on ICE ;]
It's the way the amp works, class D tends to use around half the power of a normal class AB amp, but it does have a few drawbacks also, but for sub use that doesn't really matter. I haven't a clue how well made the speaker and box is tho but I'm surprised to see Class D being used here as normally Class D amps are pretty pricey...What does class D mean?![]()
300 Watt MOSFET Amplifier
^ Yep that means it has an amp!
I got my information from the Halfrauds website, so stock the Mutant MTSPB12. It says: "Class D mono block amplifier" under the description.class d are usually much cheaper than A/B and more powerful, dont know where you get your information from, also mutant make #### car audio items and i would steer well clear
I wouldn't buy anything with a name like Mutant tho, I'd go for a brand that been around a little longer...
Well seen as it was my CD player, and you new that I bought a Sub for it, why did you post on the forum asking? To bump up your post count?.
clearly owned.
