Caporegime
- 11 Mar 2005
- Leafy Cheshire
Err, his car made it UNDERNEATH the reservation, which is pretty damn hard to do to the UK ones, here you tend to go through or over, not under really.
Erm what, they do look very similar to our design and i've said he went under it, apart from being a **** and having bad taste whats your problem?
If you happen to drive a truck then you might go over it, the whole point of a central res it to stop the vehical going over and into the other lanes of traffic.
This is your normal single sided style barrier with concrete reinforced posts in the floor raising the rail up :
The designs have now being changed to include multiple levels of square crash bar but they still stick up on posts, with the 998 being so low thats how he's gone under it BY FOLDING THE SIDE BIT IN!
If you look at the last image in that link :
You can see its a double skinned barrier with space to absorb the impact inbetween with a similar but new style flat faced crash rail + the supporting raised up posts for the whole structure.
