Also bear in mind that it's very unlikely that it will "draw" the oil up TO the pump from being dry.
PAS fluid is oil. I assume PAS fluid gets hot. Can anyone think of any decent reason why i can't use a PAS pump to pump engine oil about the place?
Not considering using a PAS pump for budget dry sumping are you? I had this idea a while back, but I have some doubts whether a typical PAS pump would have enough capacity to keep a sump evacuated.
PAS oil does get pretty hot, some cars have a simple oil cooler for the PAS fluid, which is essentially just a loop of metal tube in front of the radiator.
