using a PAS pump to pump hot oil
GeX
GeX
17 Dec 2002
Manchester
PAS fluid is oil. I assume PAS fluid gets hot. Can anyone think of any decent reason why i can't use a PAS pump to pump engine oil about the place?
Engine oil is a different viscosity of PAS fluid. The impellar blades have been design such that it can pump PAS fluid effectively at its given power rating. Theirs nothing stopping you from putting engine oil in the pump but don't expect it to work as well as if it had PAS fluid in it.
oh i don't expect it to work as well, it just needs to work. am just curious about seals inside it that might not like the heat as i dont know what kind of temp PAS fluid sees
Not considering using a PAS pump for budget dry sumping are you? I had this idea a while back, but I have some doubts whether a typical PAS pump would have enough capacity to keep a sump evacuated.
PAS oil does get pretty hot, some cars have a simple oil cooler for the PAS fluid, which is essentially just a loop of metal tube in front of the radiator.
Get a PAS pump off any sports car (just struck me), like the Corvette C4, they're stonkers and various models also have radiators to dissipate heat. Big contact patch and the necessity to provide enough grunt to keep track through 1g+ cornering at fast speed = overbuilt power steering system! :D
Dunno how ATF (which is pretty much what it uses) is equivalent to in oil viscocity, mind. Simon?
I put thicker stuff in it too, like really thick (honey consistency) - pumped it no troubles and people run that for thousands of miles on end without issue. Don't know what kind of pressure it's generating though, or how it'd perform with several restrictions, for obvious reasons...
You can get specific scavenge pumps reasonably priced though....for such a critical component I'd be wary about nailing something together when a 'proper' equivalent is availiable.
http://cgi.ebay.co.uk/Formula-Ford-...mp_W0QQitemZ110349854251QQcmdZViewItemQQptZUK
For example! :)
not dry sump, i still have that GT15 turbo on the shelf but am out of useable engine bay space, so am toying with the idea of fitting it at the back. oil feed is easy, but i'm trying to work out a cheap way of getting the oil back. My cinq does not have power steering, but i do have a pump and pulley that fits the 1368cc engine sat on the shelf. All i'm going to do is scavenge it from the oil return and pump it into the top end of the engine.
Lashout - i'm hoping to use the one i already have. I have looked and can get a suitable electric mocal oil pump for around £108+vat BUT end of the day this is a cheap car and just a bit of fun.. and i've spent enough on it already !!
Sounds cool. I'm sure you won't need much to get the oil back to the sump.
Electric PAS pump could be a good solution that doesn't involve pulleys and the like, quite a few of those around. Plus you could control it if required.
i had a look at them (PSA ones) and they were going for around £30-£50... which is :( like i say, i have a belt driven one and the drive for it ready to fit, so makes sense to use that.
the only thing.. i will need to move my rad to the otherside, but with the air intake at the rear of the car, that won't be a problem.
could pump it into the dipstick hole, i dont want to cut holes in the sump - i did on my old engine but it had a thin steel sump, this one is a cast alloy.. i dont think it'd like being drilled, and they cost too much to replace.
