Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Where is the pool table ?
Where is the pool table ?![]()
But how much of that do you actually need. For starters you have 2 camera bodies, unless oyu are shooting a wedding or such like then you don't absolutely need 2 bodies. Perhaps on safari when you want the Nikon 14-24mm 2.8 on your full frame camera and a 200-400 on a crop camera so you can fire away at animals and landscape instantaneously....
As for the laptop. IS it needed every shoot?
Similarly with lens choices. I normally decide on a set of complimentary lenses. E.g., there is no point taking an 5mm 1.4 lens into the mountains. And I've found that taking say just 2 primes, or a ultra wide angle (10-20mm) + a high quality telephoto (80-200 2.8) works out well to give good distinct photos, instead of hundred of generic composures that a walkabout zoom (24-105 etc) gives.
But I know you do some semi serious photo shoots with some models etc, so probably you like the choices and redundency.
I would also be tempted to put your 1mk3 on the bottom of the bag since its ehavier than the 20/40D body??
Pretty much every shoot I do is paid at the moment, to not take two bodies with me is a ridiculous idea....only takes one malfunction and there goes the reputation that is taking so long to estabilish.
No it's not needed for every shoot, it doesnt always come along, but I'd say 50% of the time it does come out to allow me to show clients properly how things are going/back things up
I only have 4 lenses :s 2 primes for low light work, and the two zooms that cover almost every situation......can't say i'd leave any of them at home for any shoot, never know when you might want the super soft bokeh of the 85mm or just can't get a fast enough shutter speed without dropping down, and the combined weight of both of the primes is 600g....hardly gonna be making a difference is it?
The model stuff is the only thing that i do at the moment that isnt totally serious, and one fo the only things that I tend to share on here as most clients dont want their photos plastered all over random forums. Even then, the modelling stuff is moving into paid work at the moment too, so yes flexibility and redundancy is important.
Yeah, if you are predominantly shooting paid work, then the gear seems reasonable.
I was just wondering if you took all that gear on personal photography excursions.
