No, but they were fitted in pairs and they have even wear. You can't guarantee how those part worms have been treated and if they have even wear and tread pattern. Don't make such a silly remark.
But you can guarantee how your car was treated before you bought it and know its never been kerbed or had a puncture repaired dont you!?
You can actually view the tyres before you get them fitted to the car...... the garage will show you the makes and wear on the tyres and usually let you pick which you want.
Say you get a puncture in one tyre which isnt repairable. The other tyre has 4.5mm left on it. They are £150 new but the garage say you can have a "part worn" one of the same brand/model for £40 which has 4.5mm tread on it.
Do you buy the part worn, or do you shell out to have two new tyres are £300. I would buy the part worn one, and I imagine a great many other people would do provided the tyre is itself completely fine which they are supplying.
