Man of Honour
- 21 Nov 2004
For me it comes from the graphics card. I have a coolermaster 850W which is more than enough! Of course, it is possible that if you are straining the PSU it would do that also.
my card has a EK water block on it and still makes the noise so its not the fan
i only noticed it again when goign to water the stock air cooler was so loud i couldnt hear anything else lol
yours must be much louder than mine then.
i kept the fan at 40% when i was on airr and couldnt hear the squeal then my pc was also under the desk.
now it is on top of my desk and just to my right.
Im happy with the cards performance and never goes above 36 degrees on water so i choose to live with a bit of noise during loading.
I got a 280 when ocuk were selling them cheap a few weeks back...had a 650w PSU in, with low amps on the 12v rail.. anyway, tried the card, worked fine, but did squeal during loading /menus.
Bought a new coolermaster PSU, 750 modular...squeals SO loud in games, not just loading now.. was so bad i RMA'd the PSU, same problem with replacement, went to OCUK and was told it was sorted, got it home to find it wasnt. RMA'd the graphics card, ended up getting send a 285..
The 285 still squealed too...so, in the end, i just put the older, less powerful PSU in my main system, no more squealing!. Shame..just wasted 80 quid on a psu!
I did some reading and found out that the squealing is a result of too many amps going down the 12v rails.. not sure how true this is, but i can believe it, seeing as it doesnt squeal with a less powerful PSU.
i run an enermax Galaxy 1000w
i also have an enermax liberty 620w il try it on that see if it makes any difference.
I thought that too and *********** havent mentioned any restocking fee with the PSU I'm taking back also.
RoEy
