Hi,
Need a bit of advice. My pc keeps crashing when i try to play games.I have put in a new psu 500w which is ample as the old one was 300w from new.I havent changed any hard ware or memory its as it was when i bought it.I have run memtest and taken out the stick or memory and reseated it in another slot and reran memtest every thing is ok.Changed the drivers for the card cleaned the pc of dust.
My system is P4 3.4 prescot 512 ram fx 5500 and its a fijitsu seimens pc.All temps are ok when running it as i have checked in the bios and other software.This is the first error i get in the event log
Event Type: Error
Event Source: System Error
Event Category: (102)
Event ID: 1003
Date: 01/03/2009
Time: 12:38:26
User: N/A
Computer:
Description:
Error code 1000007f, parameter1 00000008, parameter2 f8b15d70, parameter3 00000000, parameter4 00000000.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 53 79 73 74 65 6d 20 45 System E
0008: 72 72 6f 72 20 20 45 72 rror Er
0010: 72 6f 72 20 63 6f 64 65 ror code
0018: 20 31 30 30 30 30 30 37 1000007
0020: 66 20 20 50 61 72 61 6d f Param
0028: 65 74 65 72 73 20 30 30 eters 00
0030: 30 30 30 30 30 38 2c 20 000008,
0038: 66 38 62 31 35 64 37 30 f8b15d70
0040: 2c 20 30 30 30 30 30 30 , 000000
0048: 30 30 2c 20 30 30 30 30 00, 0000
0050: 30 30 30 30 0000
the second one i get is
Event Type: Error
Event ID: 1003
Date: 27/02/2009
Time: 17:47:53
User: N/A
Computer:
Description:
Error code 1000007f, parameter1 00000008, parameter2 80042000, parameter3 00000000, parameter4 00000000.
Data:
0038: 38 30 30 34 32 30 30 30 80042000
These are blue screen errors it only seams to happen when i try to play a game and the pc screen turns it self off any ideas thanks.
Event Type: Error
Event ID: 1003
Date: 01/03/2009
Time: 12:38:26
User: N/A
Computer:
Description:
Data:
Event Type: Error
Event ID: 1003
Date: 27/02/2009
Time: 17:47:53
User: N/A
Computer:
Description:
Data:
