perfect example of a "Nutritionist" here:
http://www.guardian.co.uk/media/2007/feb/12/advertising.food
Why not mix it up a bit? This morning I had 2 fried eggs and 2 piece of bacon, followed by bran flakes then a small handfull of blueberries and a small handfull of frozen rasberries, blended up with a bit of water made 3/4 pint of sort of smoothie.
Unless it was 'healthy choice' bacon and you cooked the eggs without the yolk, that's not a very healthy breakfast.
Go running.
The bacon isn't great, but the eggs are fine; only about 1.5g of saturated fat per egg.
There is nothing wrong with yolks I repeat sod all wrong with them, eating just the whites is a waste
No carb diets are ok...but the problem is when you go back to eating normally..Most people balloon.
what? of course you would balloon if you eat what you did before, that is kinda obvious...
also, it is as simple as carbs out > carbs in.
Ok well i thought id share this plan i got direct from a nutrition specialist who is quite awesome at her job and swears by this diet and excercise plan.
Seriously, does that slendertone abs belt really works? I fail to see how something viberates on your belly would give you six packs. (or on your arms, by claiming 10 minute session is like doing 200 push ups.)
I'm wary of anyone that calls themselves a nutrition specialist / nutritionist - it's a completely non-regulated arbitrary name with no accreditation. I could wake up tomorrow and call myself a nutritionist, hell I've probably done more actual research into diet than most of them.
edit: should have read the whole thread first; Goldacre is a legend.
Ok..so if thats the situation, do they stay on a near zero carb diet for the rest of their lives?
Did you mean calories?
BUT unlike a lot of other companys their products actually work with prooven results.
It works amazingly Because it doesnt vibrate it contracts your abdominal muscles with the help og conductive gel pads and electricity quite quickly in a short space of time every 10 seconds for either 10, 20 or 30 minutes with a range of intensity settings.
Slendertone has been going since the 50's and started off doing work for people that had muscle wasting due to operations or other various reasons but under a different name, when the weight loss craze kicked in they named themselves slendertone and made a bomb BUT unlike a lot of other companys their products actually work with prooven results.
Homeopathy is a $20 billion industry - doesn't mean it works.
Functional Electronic Stimulation (FES) does indeed have a use in rehabilitation, but it's not going to build muscle / lose fat in the way Slendertone would have you believe.
