Half-Life 2 FakeFactory Cinematic Mod V9.5 HD Mod (9GB!!) on Vista x64??
30 Sep 2008
Any one installed this and got it running on Vista x64??? Its a big mother and im not downloading it if it doesnt work.
"The FakeFactory Cinemeatic Mod v9.5 HD Complete is a 9 GB file that takes time to download.
- Requires 32bit Windows OS on a gaming rig with 4gb of ram, dual core CPU, high end 512MB graphics card and DirectX 9"
Not used it yet, but planning to download it at some point. Where did you find the full v9.5 file? I can only find v9.0 & the v9.5 update.
- 3870 512MB in crossfire & Q9650 quad, 4GB ....i put off installing these mods because of only 2GB of RAM.
Loved the HL2 games
Oh well i could run Crysis @ 1920*1200 fine but had to turn down the post processing a few times. Oh and on the big levels because 512MB wasnt enough.
Il download it. Anyone suggest some URL's. Im not joining filefront
These are the ones I'll be downloading:
v9.0 BASE: http://games.on.net/file/23189/HL2_FakeFactorys_Cinematic_Half-Life_2_Mod_Base_v9
v9.5 UPDATE: http://games.on.net/file/23250/Fakefactorys_Cinematic_Mod_V9.5_Update
v9.0 HD Addon: http://games.on.net/file/23190/HL2_FakeFactorys_Cinematic_Half-Life_2_Mod_Addon_v9
I'll install them in that order as well.
As much as a Crysis would? ;)
Quite possibly, even the creator of the cinematic mod has said that he's pushed the Source engine to it's limit which is why it lags.
Not sure if this will help but.......
When I upgrading to 8 gig of RAM, HL2 was the only game that wouldn't work. The quick fix was:
Open steam, my games, right click on HL2, properties, set launch options and add the comment "-32bit"
Worth a try !
Theres a 9.51 you can get via torrent whichiis worth getting, dont need 9.5 update with it either as both rolled together. Good mod! It stutters and has some slug areas compared to normal. Saving and reloading usually sorts this.
Works fine on my Vista 64 (i7 w/ 6GB ram). It's incredible. Well worth it if you're PC can cope.
Is it available without a torrent? How bigs the file?
Am downloading this as we speak!
*laughs at speed until VM throttles to 5MB until 11pm*
Unfortunately only working host I could find is torrent via piratebay, others were down, seems fakefactory torrented it as his usual upload site is apprently quite slow to validate and approve new uploads, and he wanted the update out quicker. The file is a little larger than the 9.5 update; as it effectively contains that update plus more.
Would have thought 64bit would have worked since it can address all that extra RAM instead of just up to 4GB ?
I will be home later to test mine!
Well I had no issues playing it and did not need to use -32 bit switch, no stuttering, no slowdowns. In fact HL2.exe didn't even use a GB of RAM in total.
Looks nice though...
dl it now looks great
put some screenies up when i get it going .
arghhhhhhhhhhhhhhhh it wont launch cause i dont have hl2 ep 2 noooooooooo!
is there a demo of ep 2?
and would this work as it just asks for content.
sorted it as a awesome friend gave me ep2 :cool:
installed mod but hl2 crashed after second loading scene :(
ep1 works fine and alex does look well lurvleeee :D:D
ep2 i havent done anything on it and i think you need to have completed it to work.
wheres best places to put up high res screenies as imageshack wont let me cause too big :( (prefer somewhere where i dont need to register)
shrunk down ;(
