My new RIG :)
6 Jun 2005
Plymouth / Cambridge
Ok, Hi all the week has come where i have finally saved up enough money, putting away £300 a month to replace my aging 6 year old PC that has served me well. it got me all through UNI and a job in the games industry but now its on its last legs :.. (
so this is what i would like for my new RIG, not 100% top of the line, im a realist but what do you all think? this gonna be good? am i missing somthing or making a fatal error on somthing, should i hold out a few weeks because
... any Advice is great.
All conpontents and prices from OCUK :) as of 1st march
Monitor : 26" Samsung SM-T260 26" Widescreen LCD Monitor - Rose Red
Processor : Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366) - Retail
Motherboard : Asus P6T Deluxe Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
Graphic Card : BFG GeForce GTX 285 OC 1024MB GDDR3 PCI Express 2.0 Graphics Card - Retail (Core: 702MHz)
HDD : Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ) X1
RAM : Corsair 6GB DDR3 XMS3 PC3-10666C9 1333MHz (3x2GB) Triple Channel DDR3 (TR3X6G1333C9) X2 (12gb!)
DVD : Pioneer BDC-202BK 5x BD-ROM + 12x12 DVD±RW Serial ATA Dual Layer ReWriter - (Black)
PSU : Tagan PipeRock TG900-BZ 900w Modular BZ Series PSU
OS : Microsoft Windows Vista Home Premium SP1 64-Bit - OEM (66I-01939)
Case : NZXT Hush Classic Series Silent Midi-Tower Case - Black (No PSU)
CPU FAN : Asus Triton 88 Quiet CPU Cooler (Socket AM2/LGA775/LGA1366)
NIC : Linksys WMP110 300Mbps Wireless-N PCI RangePlus Adapter
TOTAL £1935.32
i have to add that this forum has been really great really appreciate everyone who has helped me along the way over the past few week in helping with advice
THX GUYS!!!
P
Modifications i would make.
Change the PSU to a Be Quiet 850w
and
with that budget i would get a better case (Lian LI, Antec P182, or if you like lots of lights Antec 900)
and
24" Screen
i would go for a ATI 4870 X2 (i prefer ATI, had problems with Nvida in past). Really, if your running 24" a 4870 would do you fine.
and
CPU fan go for the Noctua
ok thx for your amazingly quick responces as allways
the PSU : i could go for thet one that you mentioned "Be Quiet 850w" whats the reson for me switching? targens are pretty OK arent they
the 26" monitor im kind of liking tho be much better for movies and 3D work (remember i do bring work home) is there any reason why i should not get a 26"?
the NZXT Hush Classic Series has loads of noise padding in the case, i'd like to get one that will isolate at least some of the noise do teh ones you mentioned do this
Ram yep 12gb is a bit execessive..but then its pretty cheap for 12gb really...im not over clocking it so its standard stuff. how much should i get considering i need a PC that can Handle load of APPS open at one time 3dsmax Zbrush PS... sure more the merrier?
CPU fan which Noctua this one "Noctua NH-U12P SE1366 CPU Cooler (Socket LGA1366) Noctua NH-U12P SE1366 CPU Cooler (Socket LGA1366)" : )
thx again
P
how about...MUCH better :p
Product Name Qty Price Line Total
Gainward ATI Radeon HD 4870 X2 "Rampage GLH" 2048MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail (471846200-9856) £425.49
(£369.99) £425.49
(£369.99)
Samsung T240HD 24" Widescreen LCD Freeview Monitor (LS24TDDSUV/EN) £298.99
(£259.99) £298.99
(£259.99)
Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366) - OEM £229.99
(£199.99) £229.99
(£199.99)
Asus P6T Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard £204.69
(£177.99) £204.69
(£177.99)
Western Digital VelociRaptor 150GB 10000RPM SATA-II 16MB Cache - OEM (WD1500HLFS) £155.24
(£134.99) £155.24
(£134.99)
Coolermaster Real Power 850w Modular Power Supply £120.74
(£104.99) £120.74
(£104.99)
Antec P182 Super Midi Tower Case - Gun Metal Black (No PSU) £118.44
(£102.99) £118.44
(£102.99)
Corsair 6GB DDR3 XMS3 PC3-10666C9 1333MHz (3x2GB) Triple Channel DDR3 (TR3X6G1333C9) £106.94
(£92.99) £106.94
(£92.99)
Microsoft Windows Vista Home Premium SP1 64-Bit - OEM (66I-01939) £91.99
(£79.99) £91.99
(£79.99)
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ) £83.94
(£72.99) £83.94
(£72.99)
Noctua NH-U12P SE1366 CPU Cooler (Socket LGA1366) £57.49
(£49.99) £57.49
(£49.99)
Linksys WMP110 300Mbps Wireless-N PCI RangePlus Adapter £51.74
(£44.99) £51.74
(£44.99)
Asus DRW-20B1ST 20x DVD±RW SATA Dual Layer Rewriter (Black) - OEM £20.69
(£17.99) £41.38
(£35.98)
Arctic Cooling MX-2 Thermal Compound £4.59
(£3.99) £4.59
(£3.99) Sub Total : £1,731.85 Shipping cost assumes delivery to UK Mainland with:
DHL Select Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £14.99 VAT is being charged at 15% VAT : £262.03 Total : £2,008.87
I have the Antec P180b and that has soundproofing its similar to the P182 except that has better wire tidying.
Be Quiet PSU are really well built, quiet, and realiable. Tagan are fine but i would go for either: Be Quiet, Corsair, or Coolemaster.
The above spec is pretty much what i would go for. Apart from a Be Quiet PSU:)
I would recommend getting a Zalman or Be Quiet PSU, not that the Tagen is rubbish just personal choice. You need something ~650-750 watts, no harm in getting an 850w, beyond that it's over-spec.
The monitor size is entirely personal choice - go with what you want.
I don't know that case, I use Coolermaster and Lian Li - good solid cases. Noise is unavoidable to a large extent but be careful not to buy a flimsy case that will resonate and magnify what there is.
Go with 12GB RAM if you want - it's cheap right now so if you can use it why not. I have 9GB in mine.
The Noctua is good, but I have a cheaper Akasa Nero and clock my 920 to 3.6GHz with no effort. Savings are minimal though.
The only significant change I would make is the Spinpoint 1TB - I;ve seen too many failure reports with this drive to feel comfortable recommending it, lots of folk swear by them but too many complaints for me to buy one. I would get a 1TB WD Black for storage, and either a smaller additional drive (320GB) or velociraptor for boot..
ok thx been taking on all your opinions and changing what i agree with as well, still stuck on which case has to be a silent or one that is going to reduce the noise...looks dont matter really
so far :
HDD: Western Digital Caviar Black 1TB SATA-II 32MB Cache - OEM (WD1001FALS)
DVD : Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
PSU : Be Quiet! Dark Power Pro 850W ATX2.2 Modular SLi Compliant Power Supply
Case : NZXT Hush Classic Series Silent Midi-Tower Case - Black (No PSU) (undecided)
CPU fan: Noctua NH-U12P SE1366 CPU Cooler (Socket LGA1366)
Total :1877.87
THX Kennysevenfold your right i dont need a blue ray drive : )
Swap the case NZXT are not good. Not very spacious inside either. If you dont want to spend anymore go for the Antec 300. You really won't regret paying extra for a good case especially an antec p182. I case you will be able to keep for your next upgrade so its a worthy investment. One of my favourite parts of my new build was my Antec P180.
Otherwise a very nice spec. I like the PSU choice :)
I
well i will get a SSD in my next upgrade right now they are to pricey for what you get. when a 500gb SSD is some what affordible i will but now i think is not the time...would love to really would but not yet :)
ohh... just noticed the P182 SE i guess the SE stands for "shiney edition" very nice thinking of this or the COSMOS 1000 althogh the CM is huge... COSMOS 1000 any good?
think im going to go for the "Antec P182 Super Midi Tower Case - Gun Metal Black (No PSU)" case shame the special edition one is not avalible anywhere would have much prefered that but....
so here is the final spec
Case : Antec P182 Super Midi Tower Case - Gun Metal Black (No PSU)
Thx All for your help : )
P
I sitll reckon a SSD even if it's small in size for the OS would make a gigantic improvement in overal performance and loading times. You're right though, they're costly at present. As long as your willing to go through the hastle of reintsalling the OS when you buy one in the future.
GTX 285 is a massive waste of money mate. For that amount of scratch you could get two HD4870 1GBs which would be a lot faster.
