- 3 Nov 2004
- UK
If you're using the low level input (from the receiver, i.e. not high level speaker input)Do I need one or two phono to phono leads or do I need a Subwoofer Y-Splitter lead
If you only have a single sub woofer output socket on your equipment, then connect up using one of the pairs of leads (red to red). In this instance use the (Mono) input on your Monolith sub.
http://www.bkelec.com/HiFi/Sub_Woofers/Monolith manual.pdf
http://63.148.251.135/redirect_serv...s&file=SN_29344753A_TX-SR876_NR906_En_web.pdf
684 as rears good for you
