Mine won't run through steam for some reason, I have to navigate to the installed folder and run the game executable. I also own the retail but can't add the key to steam since it thinks I already own it.
For those of you who have the DVD, move your installed UT3 draw to the steamapps \common\ draw then activate. it may tell you that you already own the game, then just down load free weekend black edition & it will say 20% installed it will clime fast as you already have it installed.
Yeah, I've done exactly that, but it won't allow me to enter my cd-key, at least until the trial is over. Steam says 'this game is currently unavilable, please try again at another time'. I know it works because launching it manually works ok, though not sure what key it's using since I haven't tried online.
I installed patch 2 and titan pack manually.
Number 3 took me since 6pm yesterday for it to start, numerous restarts with different countries selected, just happened by random this afternoon.
...and still there's only about 6 servers!
Great game but completely dead.
am i the only one here that has the patches installed and runnng???
I installed the game from DVD, patched it & titan pack manually. ran it, used the keycode like normal. Moved it to Steamapps/common then install the steam version over the top which is quick & it will show up in your steam games & run like normal steam games, but a new key that it gives you will need to be activated after the free trail.
Problem with Steam now days is that the games are getting so BIG (10GB+) that its not long before your monthly bandwidth allowance is gone..![]()
I know Pixel has effectively just said this, but if you have a package from your ISP limiting you to anywhere near 10GB a month, I would be dropping them faster than you can say "get a decent ISP/package!".
all other game modes work perfect though, i like the new 'betrayal' and 'greed' modes
and the 'juggernaut' titan mutator modActivated my retail key no probs but had the same error. Turned out I needed to mark all the ut3 directory as read only since I forgot to when I copied it across.
I i forget that part. you got to turn off the read only you mean.
