The 360 motors and the PS3 motors are more or less identical, but the 360 motors have heavier weights on them. The 360 controller vibration is a lot stronger as there is more power supplied to the motors than on the PS3 pad.Also arent the X360 rumble motors more powerful than the DS3?
Its 'just' a PS3 controller, obviously it will no longer work with a 360I wouldn't have thought this was possible due to the proprietary nature of console controllers.
Are both circuit boards live at the same time? Is it possible to control both the 360 and PS3 in the same game at the same time?
Edit: Also the PS3 controller board would be tuned for PS3 components, so doesn't driving it off 360 bits throw the tolerances out? e.g. pressing down on the trigger encounters the dead-zone earlier or later.
It just utilises the inputs from a 360 board and 'passes' them to the PS3 board to handle so things like deadzones etc are not a problem.So the 360 board isn't actually active then, you are just utilising the board and extending the connections to the PS board?Its 'just' a PS3 controller, obviously it will no longer work with a 360It just utilises the inputs from a 360 board and 'passes' them to the PS3 board to handle so things like deadzones etc are not a problem.
how about you save $750 and buy two controllers instead.
what a stupid idea and waste of money if anyone buys this..
it has a 100% more better chance to break than the official single ones..
No offence mate but you've clearly not thought your post through.how about you save $750 and buy two controllers instead.
The PS3 and 360 stick shafts/caps are a direct swap so this would be very easy if you wanted to do itBubo said:Nice idea and all but for me the only thing wrong with the ps3 pad is the lack of a concave dimple in the analogue sticks for your thumbs to lock into. I have seen mods elsewhere which transplant the sticks from an old style xbox pad to the ps3 pad
The Xbox 1 Controller-S sticks have a larger dome on the bottom of them so would require some sanding down to prevent them fouling on the PS3 stick mechs / PCB when tilted.how about you save $750 and buy two controllers instead.
I can now confirm this is possible if not a little tricky... As for the D-pad, as I barely ever use it I wasn't that bothered although I may have a go at fitting it with some old spare controller shells I have just for the sake of it.
An employee of Sony computer entertainment (which I found quite ironic!) has commissioned me to build him 2 of these controllers and requested that the PS3 Dpad and button faces also be fitted into the 360 shell.
when I saw this I presumed it was ps3 controller on xbox 360 the way it should be ?
