Hi
Ive been having a problem lately with my 4870 X2 card. When running a fullscreen game, i get what i can only describe as VHS style tracking lines. Put it in windowed and its fine.
So far ive tried...
Other port on card (no change)
Another monitor on both ports (that mon did same)
DVI cable (no change)
Went back to 9.1, loaded COD4 to test, first time fine, loaded again, lines, but less than on 9.2.
Not sure if its needed..but heres the spec.
Q9550
8gb OCZ Reaper
4870 X2
4870 1Gb
Asus Rampage Formula
Im not sure when the problem started tbh, i play most games windowed as i use irc etc a lot. But obviously if its a faulty component, i want to get it sorted before warranty runs out etc.
I was going to try and roll back to 8.12, but thought id post here for some advice
Cheers
So far ive tried...
Q9550
8gb OCZ Reaper
4870 X2
4870 1Gb
Cheers
