Yes, RAID 0 is my plan for two drives. Though tbh I don't see the point if I can have the same storage space in one drive - taking up less space.
the point is that RAID0 is for increased speed.
Would the two smaller drives be faster than the WD?
Does using RAID0 actually increase the risk of drive fail?
then I suppose it could be argued that the risk of failure is not double (yet still more than one) when using two drives.
In general, yes.it is double, isnt it..
if you have one drive and it fails its 1/1
if you have two drives and one fails its 1/2
Read/write heads are there in any case if you have drive running.you're only writing half the amount on each drive in RAID0, so the head may be over the platter for slightly less time.![]()
