Since when?
That doesn't make sense, you would transfer film to digital at full 4k resolution to create the digital master and then reduce the resolution later, you would not scan and edit the film at a low resolution as that would result in artifacts.
I thought they were supposed to be out end of this year just not the extended cuts....which are being held back until after the release of the Hobbit?
I read the 1st one is coming out the end of this year on blu-ray.com. New Line may well do what they did with the DVD release. (standard disc then the extended SE 6 months later) or they will release all 3 when the Hobbit comes to the Cinema.
Isn't the hobbit set for release in 2012?!
Lucas is in no rush to get SW to Bluray either.
